    Mar 2008
    India
    How to join to MKV files? Any tool please?
    Dec 2004
    Triptonia
    "I'll give you five dollars if you let me throw a rock at you"
  3. Assuming you mean joining files end to end, you can use avidemux and the append function. The files require the exact same specifications (dimensions, audio etc...)
    Open your .mkv, append the segments using file=>append, leave audio, video set to copy, change the format to "mkv", press save with extension (e.g. "joinedfile.mkv")
    Mar 2008
    India
    Not working in case of AVIDEMUX...any other tool plz?
    Mar 2008
    India
    Thanks it worked with MKVMERGE....
