let me get this straight, it seems like
powerDVD only let you change the region like 4-5 times then
you get locked in to the region you last used
for example right now I'm lock at using region 3 code
any way to get around this?
i thiought the drive it self had the restrictions. Try DVDGenie.
Well, I am the slime from your video.
Oozin' along on your livin'room floor. -
Every DVD Software Player (and Windows itself) locks up after 5 min of region changes, and gets locked on the last region you played, use a program like DVD Genie to enable you to play without getting your region locked.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Help ! Panasonic BD-60 UNLOCK DVD region code (Region 1)
By aexp in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Sep 2009, 10:24 -
Need code for pioneeer bdp lx70 code for multi region ...
By SHERWOODSelectrical in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Nov 2008, 12:42 -
Lost Cd to play dvdfilms after i have installed powere dvd cyberlink
By chikenkat in forum Authoring (DVD)Replies: 0Last Post: 12th Aug 2008, 18:36 -
Limited Label Beluga DVD40 Region hack
By semtex in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Jun 2008, 13:28
