So i'm using Premiere Pro 1.5, and trying to edit some widescreen movie footage I have taken.
Anyway, the resolution of the movie file is 704 x 576. Once I import it into the program and drag it onto the timeline it is squashed into a square in the main sequence window and I can't figure out how to get it back to its original proportions for editing.
Any help? Thankyou.
I've made the main project settings 16:9 as far as I know, here are some screenshots.
The main settings i've used to begin with -
http://i33.tinypic.com/294td9s.jpg
The properties of the file, which when played with VLC media player shows up with the correct aspect ratio -
http://i35.tinypic.com/k4tbi1.jpg
The squashed video - http://i38.tinypic.com/2vseqeo.jpg -
For reference I figured out the solution.
Each individual video imported has to be tweaked, right clicking the files and choosing "Interpret Footage" gave me the appropriate options.
Thanks.
[premiere pro] i can't work in 480p (854x480) resolution, how to do this ?
By Michael REMY in forum EditingReplies: 14Last Post: 1st Jan 2016, 22:55 -
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 01:10 -
1024 576 resolution not full screen in mpc
By mrwonker in forum Software PlayingReplies: 4Last Post: 18th Jul 2011, 15:40 -
720 x 576 (2703kbps bitrate) AVI for Archos 704
By drstew in forum Portable VideoReplies: 10Last Post: 31st Aug 2008, 13:49 -
dvd plays at 720 x 576 but when ripped goes to 352 x 576 and is squashed
By aljolson in forum Newbie / General discussionsReplies: 12Last Post: 8th Jun 2008, 11:54
