Results 1 to 9 of 9
    Jul 2008
    when u use shrink is the file it creates automatically an "iso" file, or is there some place to change settings to create an iso file. I believe an iso file is different than the group of files i am getting when i use dvdshrink. can anybody clue me into the specifics. i am new to this of course and need your help. thank you very much
    Apr 2004
    Miskatonic U
    An ISO file is a disc image. It's contents are all the folders and files you would get if you just output to a HDD folder. You can select ISO output in the Backup dialogue under Target Device. Is there any benefit other than the neatness of a single file - not any more. Once upon a time DVD Decrypter was the burning application de jour and it could only burn an ISO image. It grew up to become Imgburn, which is a lot smarter and will happily burn from a folder. I don't think I have created an ISO out of Shrink since then.
    Read my blog here.
    Jul 2008
    I got it. I just replaced dvd decrypter w imgburn, which works great. thanks for the info!
    May 2003
    Mission Viejo, CA
    I use DVDShrink within Ripit4Me to create an ISO file. I then burn that with ImageBurn or convert to Xvid with FairUse Wizard.
  5. Hi! : Almost Human, I am confused. I have ripit4me, nero 8, dvd shrink, dvd decrypter, and imgburn. How can I switch from nero burner to imgburn as a burner. I was told to use imgburn instead of nero.
    Gerald Sr.
  6. Mod Neophyte redwudz's Avatar
    USA
    You can use the VIDEO_TS folder that Shrink created and burn that with ImgBurn or use the ISO. Just set Shrink to output to your hard drive. There were a few methods to use ImgBurn automatically with Shrink but they were apparently withdrawn due to copyright problems.
    Dec 2006
    Here,where do you think?
    Hey Gerald Sr. if you mean, how do use IMGburn within Shrink to burn,I believe there used to be a version of Shrink that would allow you to automatically use IMGburn instead of Ner0....Perhaps someone can provide a link..
    However you can just backup the file to your HDD and open the resulting VIDEO_TS folder or ISO in IMGBurn and burn it...
    EDIT: looks like redwudz has got it covered.... 8)
    http://forum.imgburn.com/index.php?s=1ba8ccae4f39ab075491b33f39a1057a&showtopic=4632
    http://forum.imgburn.com/index.php?s=1ba8ccae4f39ab075491b33f39a1057a&showtopic=61
    " Who needs Google, my wife knows everything"
  8. Man of Steel freebird73717's Avatar
    Dec 2003
    Smallville, USA
    http://www.dvdplusvideo.com/DVD_Shrink_3_2_b_w_IB.zip
    Donadagohvi (Cherokee for "Until we meet again")
  9. Member Seeker47's Avatar
    Jul 2005
    I don't know about any copyright problems, but there was definitely an OS issue: this alternate version of Shrink relies upon something that is present in XP, but not present in earlier versions of Win. This caused it to always bomb out immediately on my systems, which are still W2K-based. I'll be setting up a new box running XP in the near future, so will have a chance to try this out then.
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
