Because I don't video edit very often so I can't please every person that assumes I know every detail to include?
Can you see the video on the timeline - actually see the images ? Yes
What are you selecting for output - format/type etc ? DivX avi
Are you using any effects or overlays ? Only transitions -
Never had much luck getting Vegas to output Divx or Xvid directly. It is also of concern that you can't see anything in the preview window.
A couple of things to check/try
1. Check the opacity level of your time line. Move the mouse over the top of the timline. You should get a tool tip saying Opacity is 100%. if you don't, move the mouse down to the bottom of the timeline and see if you get a tool tip saying Opacity is 0 %.. If you do, click on it and drag it back up the top.
2. Try outputting to something simple like DV first until you get the black output problem solved.
How many timelines do you have in the project ?Read my blog here.
Sony Vegas is rendering black screen
By LoveMyslf in forum EditingReplies: 20Last Post: 24th Jun 2015, 08:59 -
Black screen, but Audio is fine - when playing after rendering
By DUCKVILLELOL in forum Newbie / General discussionsReplies: 0Last Post: 14th Dec 2010, 06:06 -
Sony Vegas pro 9. Rendering Black screen
By jolehoz in forum EditingReplies: 0Last Post: 15th Nov 2010, 12:02 -
Why is Vegas 8.0 rendering complete black screens only?
By VideoMan in forum EditingReplies: 1Last Post: 25th Nov 2009, 07:19 -
Dreaded black screen after rendering in Vegas
By gash46 in forum EditingReplies: 0Last Post: 5th Aug 2008, 20:50
