I am editing some video clips on my program " Ulead VideoStudio 8.0 SE DVD" .
The clips are captured from my Sony Handycam SR42E.
When i play the clip or Project, there is no sound.
What can i do?![]()
Thanks for your help.
Results 1 to 10 of 10
Never spend your money before you have it.
I know the program is old, i just started to use today.
Should an old program work yesterday and today?
I can't affort a new one at the moment.
Do you have any idea why it is not working? I mean the sound, may be need to
download some codec (where)????Never spend your money before you have it. -
Downloaded the program , but not much help.
the file audio are MODD.Never spend your money before you have it. -
are you sure? this says ac3...
http://www.sony.co.id/product/dcr-sr42e/sku/dcr-sr42e+++e34/tab/sc1?site=hp_en_ID_i&ajax=true
If those specs are correct, it's just MPEG2; and there are dozens of free editors...you could try installing ac3filter and ac3acm if ulead relies on external codecs -
here is a screeshot of my file
did downloaded the 2 ac.., then when on Ulead but don't work.
i'll try a few more time ...and let you knowNever spend your money before you have it. -
Ulead video studio 8 se, dose not support ac3 audio source as input
Convert audio to pcm or mp2
Demuxer : Mpg2cut2
Encoder audio : Besweet
Problem with Ulead Videostudio SE DVD and EasyCAP
By Majora in forum Capturing and VCRReplies: 17Last Post: 20th Nov 2011, 03:51 -
Author HD-DVD using x.264 Ulead VideoStudio 11 Plus???
By blkdumplin in forum Authoring (Blu-ray)Replies: 13Last Post: 18th Mar 2009, 08:48 -
Something faster than ULEAD Videostudio SE DVD?
By snafubaby in forum Authoring (DVD)Replies: 3Last Post: 2nd Mar 2009, 00:11 -
Ulead VideoStudio 10 + Dazzle DVD Recorder = No Sound???
By firebirdta84 in forum Capturing and VCRReplies: 1Last Post: 18th Jan 2008, 08:26 -
Audio problems with Ulead VideoStudio 8
By beanosirra in forum Newbie / General discussionsReplies: 4Last Post: 14th Jun 2007, 09:35
