i used ripit4me, dvd decrypter, n shrink which gave me a great dvd, but will only play on my pc. i tried using divx to dvd but only got some 19FB file i dont know what to do with. any suggestions on how to convert my movies into a readable format for my dvd player. i am new to this so pretend u are talking to a 10 year old.....who knows little about computers! thanks for the help
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
You say this,
"used ripit4me, dvd decrypter, n shrink which gave me a great dvd, but will only play on my pc. Then this "i tried using divx to dvd." why use divxtodvd when you already have a "great DVD"....
Explain from the start your steps/methods used...
If you've already burned a so-called "great dvd" what media(blank discs)did you use.....
And if we pretend you're a 10 year old, you might ask mommy for permission first..." Who needs Google, my wife knows everything" -
And are you sure your DVD player even plays burned DVDRs? Check the player database for yours to see if there are any comments about that one way or the other:
https://www.videohelp.com/dvdplayers -
i used ripit4me then dvd decrypter then dvd shrink. this worked fine on my pc. but when it did not work on my dvd player, i also tried to run it through divx to dvd to see if it would make it compliant with my dvd player. no luck. i have a philips dvp 642 which should, and has run dvdr. i read here that dvd decrypter is out of date n i should use dvdfab instead. any thoughts on that? oh yeah, n i meant i am computer inexperienced (which means explain it to me like im an idiot, thats all!). thanks for the help
Well since you state that using the above tools,it works fine on your pc,then maybe you don't need FAB for this particular flick...However you will eventually need DVDFab,IMO...
Do you now have a compliant VIDEO_TS folder on your pc? Does it play all the way through? If so ,than just maybe your standalone doesn't like the media (disc)you burned, what is it,and what tool was used to burn it?How did you burn it?
Maybe try ripping with DVDFab HD Decrypter> DVDShrink>then burn with IMGBurn....
http://club.cdfreaks.com/f153/guide-simple-dvd-backup-using-dvdfab-hd-decrypter-dvd-sh...mgburn-234028/
http://forum.imgburn.com/index.php?s=a96bb38c0927a25eb20e26dab5e14136&showtopic=4632
Hope these guide help...
And there really is no need to use DivxtoDVD ,since you've already ripped it to your HDD(pc) successfully, so you say!...
Just curious but ,you're not trying to convert divx/AVI to DVD right?" Who needs Google, my wife knows everything" -
I have been using nexxtech dvdr, n burning with the software that came with my pc. the software has burnt successful other disks. im gonna try your suggestion with fab>decrypt>img. thanks for the help. more to come
I'd definitely use better media,and what burn SW came with the PC?
Verbatim and TY (Taiyo yuden ) media are very reliable...." Who needs Google, my wife knows everything"
Standalone player will not play DVD
By Chala in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2010, 03:09 -
One specific ripped DVD folder does not play in Windows Media Player
By aslaksen in forum Software PlayingReplies: 2Last Post: 11th Apr 2010, 18:16 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 16:46 -
DVD will play in PIONEER Standalone but NOT Recognise in...........
By rockonvidtrade in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2009, 23:14 -
VOB to DVD - Doesn't play in Standalone
By simonsickboy in forum DVD RippingReplies: 9Last Post: 15th Feb 2008, 10:12
