I have been trying to use DVDFab Platinum to convert my dvd to avi and well it does it fine and all but for the fact that all the files have closed caption/subtitles on them. I am not sure why and I don't or can't seem to turn it off in the program. Is there a setting I am missing?
Conversion Settings > Subpicture > Extract to idx/sub file
-The Mang -
oh man thanks much I feel like a freakin idiot, but thanks for giving me the clue.
edit: ok, I did what was suggested and I still get text/captions all over my vid files. and I can't shut if off when the file is playing, so is it being embedded in the file itself? -
Originally Posted by Rjupiter
per Louv68: Conversion Settings > Subpicture > Extract to idx/sub file
I am following this thread because I also use DVDFab Platinum. What version, Rjupiter, of DVDFab are you using. They are up to 5.0.7.6 now, which is what I am using, and I cannot find this set of configurations anywhere in the settings menu. -
Just uncheck the subpictures box if you don't want subs (lower right hand corner)
They shouldn't be. Turn off the view subtitles option in your software player, and see if the subtitles go away. For example, in Windows Media Player, open the Play menu > Captions and Subtitles and you'll see if they are enabled or not.Originally Posted by Rjupiter-The Mang
Rjupiter's question is regarding to converting DVD's to .avi, and not have subtitles hardcoded in.Originally Posted by Malicious
Malicious's advice will work if you want no subtitles at all. When you convert them to .avi, no subtitles will be available either.-The Mang
Can rolling closed captioning be used as subtitles?
By jeanpave in forum SubtitleReplies: 4Last Post: 11th Jun 2010, 13:58 -
Closed Captioning in Europe
By Headway in forum DVD & Blu-ray PlayersReplies: 12Last Post: 5th May 2010, 10:10 -
Hardcoding closed captioning as subtitles?
By merciscool in forum MacReplies: 0Last Post: 28th Jan 2010, 06:12 -
no vhs closed captioning
By marvinwc in forum Newbie / General discussionsReplies: 8Last Post: 16th Oct 2009, 19:32 -
closed captioning problem
By jeffreyslike in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Oct 2007, 12:09
