    Dec 2006
    Italy
    hi everybody, i'm trying to do a dvd for projecting images on a wall. I would like to do a mix of winamp visualizations and some clip of mine. I've downloaded camstudio. When i capture some visualizations it seems that there are no problem, but when i import these clips in premiere pro, i can't see well, it'isnt fluid at all, and somethimes i can't see anything. Is there anybody that can tell me the right settings for camstudio? thank you
    massimo
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I recently tried Camstudio....again....and deleted it instantly. Worked for about 5 minutes after installation on both of my computers.
    Dec 2006
    Italy
    i don't have problems with the software, but i don't know which are the good settings for capturing with camstudio and, after, working the clips with adobe premiere pro...i mean which are the best codec to use?
