I have a new Sima GODV CT-200FC[. I have tried every combination of settings but am only receiving a Black/White picture on the TV. Does anyone have an idea as to what I'n doing wrong. THANKS.
Results 1 to 10 of 10
I have the GODVD between two DVD recorders with the second DVD feeding into the TV. I have replaced both SVHS cables and checked the Pal/NTSC switch. Still TV is only playing B/W. If I eliminate the GODVD, the TV plays color as it should.
If this unit has an image inhancer and there is a saturation setting, try moving it to 50%. I had the same problem with my ATI card my Nvidia Video card. Just a Guess. Good luck.
Unfortunately, it has a fixed enhancer with ifferent modes. Have tried them all to no avail.
If you are trying to convert between NTSC and PAL....you still need a DVD player/recorder that can output a "true" NTSC or PAL signal.
Everything shows up as B/W. I have replaced SVHS cables but still only receive B/W.
"Greenish" Black & White To "True(r)" Black & White?
By DeathStalker77 in forum RestorationReplies: 8Last Post: 30th Jul 2011, 09:39 -
DVD Palyer - black and white picture
By majstrydwa in forum DVD & Blu-ray PlayersReplies: 10Last Post: 5th Oct 2010, 11:01 -
HDTV possible on an old black & white TV???
By yoda313 in forum DVB / IPTVReplies: 10Last Post: 31st Jul 2009, 06:31 -
Black and White picture after connection
By mrs.c in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2008, 13:48 -
No Sound and black & white picture capturing VHS
By gdkcl in forum Capturing and VCRReplies: 0Last Post: 30th Jun 2007, 14:07
