Hello
im going to buy a sony hv20/30 camcorder
does any one know if it's possible to shoot in hd but capture to say a dvd recorder in sd with using the uncompressed component out (as opposed to any of the other outputs such as dv or hdmi?
although id ideally like to capture in hd, im not ready for it at the moment so if there were a way of doing this via the the uncompressed component output to a simple dvd recorder - then that would good enough for the meanwhile.
thank you
Results 1 to 1 of 1
Capturing Uncompressed Video8 and VHS-C then Compressing
By mayhampixi in forum Capturing and VCRReplies: 10Last Post: 4th Jul 2011, 11:10 -
Card for capturing HD Component Signal
By peez in forum Capturing and VCRReplies: 4Last Post: 10th Nov 2009, 09:42 -
Questions about capturing with component...
By Kisai in forum Newbie / General discussionsReplies: 14Last Post: 27th Apr 2008, 23:30 -
Asking uncompressed component video capture solution for iMac (iO LA)
By perniente in forum MacReplies: 1Last Post: 6th Jan 2008, 20:22 -
Motion Blur/Bad Quality when capturing uncompressed
By Ezekiel 4:12 in forum Capturing and VCRReplies: 4Last Post: 15th Jul 2007, 01:44
