I wasn't sure if this belonged here or in the Capturing section, sorry if that was the case.
My laptop, an HP Pavilion dv1000, has a built in firewire port and I have used this successfully to capture videos in the past. But for a month now it's been on and off, and right now it's just off. Previously when it hasn't worked I've tried a number of things that I thought made it work again, but soon after it was back to not.
I've used a few different apps to capture with no luck, but they all have the exact same problem. In windv, windows movie maker and videostudio the device is recognized by them, by the OS itself and by the camera which reports "DVin". But when I want to begin the capture in windv it freezes, and in both movie maker and videostudio both say that they are capturing but when I stop the capturing they say that the captured video is corrupted. Both videostudio and moviemaker are able to control the camera, play, stop fast forward etc, but I just can't capture with them.
So I'm wondering if anyone has encountered something similar and can guide me to a solution. I've already tried vcswap to disable some codecs (this worked in the past), removed and reinstalled the driver, and as recent as yesterday I've wiped the system clean and still the same issue.
Results 1 to 1 of 1
Windows 7 (x64) and Set Tob Box Firewire (1394) capture?
By techiejustin in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jun 2011, 20:57 -
DV to PC -- Firewire Problems; 1394 vs. USB; Capture Software
By GrayStrickland in forum Capturing and VCRReplies: 1Last Post: 27th Apr 2010, 11:27 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
Problem capturing using IEEE 1394 and camcorder
By Shabaman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 22nd Aug 2008, 07:04 -
Problem with connecting Samsung miniDV to PC thru 1394 port ?
By vu9300 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 25th Sep 2007, 01:40
