Hello,
I have successfully changed my Samsung DVD-HR753 from region 2 to
region free. Problem: when I play a region 1 DVD (USA, Canada), there
is no color. I think this has something to do with PAL versus NTSC.
My TV is PAL since I'm in Europe. Can I change the modus of my DVD
player, and if, am I enabled to reset it?
Thanx for help,
sni6ero
There are Philips DVDRs and players that'll play both NTSC and PAL discs if you set the player's "TV System" to PAL or NTSC. Should be under VIDEO settings if your DVDR is similar. That matches the playback to the TV you're using.
wabjxo:
thanx a lot for the hint. I'd found out that I simply had to change the video output from "Component" to "RGB". Color is back now.
Changing AVI Properties (Resolution, FPS etc) NTSC>PAL
By skywalka in forum Video ConversionReplies: 4Last Post: 7th Mar 2011, 20:45 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
Converting from PAl to NTSC and changing language
By BaldBill in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2009, 21:43 -
changing sup to srt for FAVC (Pal to Ntsc)
By spiritgumm in forum SubtitleReplies: 6Last Post: 13th Jan 2009, 11:57 -
PAL DVD to NTSC DVD: CCE is changing resolution (720x480 to 720x576). Argh.
By Colmino in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 19:15
