I have been trying to use some screen recording softwares including Camstudio.
But in all of these I am not able to select the option of encoding in Mp3 at 44.1kHz under "Choose Compressed Format" even if the option is present in the drop down list under "Recording Format". The maximum sample rate I am able to select is 22.05kHz. What is the solution? What is preventing the selection?
Also I would like to use x264 as the video encoder for the captured videos. But x264 is present only as CLI.
Is there a x264 installer so that its available in Camstudio video encoder options?
Thanks a lot Baldrick. It works now.
Any ideas why its wasn't working with the previous default Fraunhofer IIS Mp3 codec?
Also any ideas about
Code:Also I would like to use x264 as the video encoder for the captured videos. But x264 is present only as CLI. Is there a x264 installer so that its available in Camstudio video encoder options?
Fraunhofer's MP3 codec is crippleware.Any ideas why its wasn't working with the previous default Fraunhofer IIS Mp3 codec?
There exists the VfW version of x264 by Mr. DeathTheSheepIs there a x264 installer so that its available in Camstudio video encoder options?
(but his site seems to be down or unreachable for-the-time-being)
deaththesheep.uni.cc/
HTH.
How can I extract mp3 audio from .mov container without re-encoding?
By Danteism in forum MacReplies: 16Last Post: 3rd Jul 2010, 05:11 -
Is AAC 48.0 KHz good audio for a bluray rip?
By AndyD in forum Blu-ray RippingReplies: 3Last Post: 5th Jun 2010, 19:18 -
Is a 44.1 KHz audio capture OK for a compliant DVD?
By c627627 in forum Capturing and VCRReplies: 8Last Post: 23rd Mar 2010, 05:29 -
IE7- How to select Save as type and Encoding when saving Webpage?
By coody in forum ComputerReplies: 3Last Post: 9th Jun 2009, 14:49 -
How to convert .ts file with mp3 audio encoding into an MP4
By gauche in forum Video ConversionReplies: 6Last Post: 8th Nov 2008, 16:38
