By which software or method can I hardcode a 'srt' file into a 'ts' file as a DVB subtitle format
Almost nobody knows how to work with HDTV subtitles, so that's probably why you never got an answer. You could try asking on the forums at http://www.doom9.net, but right now public knowledge of HDTV subtitle formats is very scarce.
Not sure what an SRT file contains, but I assume you want to insert timecoded or framecoded subtitles as DVB bit maps into a DVB transport stream file? If so, look at Swift vTX at www.softel.co.uk or email sales@softel.co.uk
Why do you want to add subtitles to .ts file. I use Nero ShowTime to watch my recorded SD and HD movies with external subtitles. In Showtime options menu external subtitles must be enabled. Sometimes i have syncronisation problems. But then I use Subtitle Workshop to syncronisize them.Originally Posted by elmc
how to add a subtitle track file to an mkv file???
By Sh@DY in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 19:57 -
Add DVB Subtitles to MPEG2 Muxed (mpg) file
By edrin in forum SubtitleReplies: 0Last Post: 26th May 2010, 15:47 -
How to create a DVB subtitle in ts file
By elmc in forum SubtitleReplies: 0Last Post: 23rd Jul 2008, 10:59 -
How can I add a subtitle into ts file in DVB subtitle format
By elmc in forum SubtitleReplies: 1Last Post: 20th Jul 2008, 14:37 -
How can I add permanent subtitle in TS file
By elmc in forum SubtitleReplies: 8Last Post: 19th Jul 2008, 03:32
