Bought the harddrive from someone who said it was new but they tested it to see if it worked and i put it in the ps3 and from what i read about installing new hdd to the ps3 when i turn it on the ps3 should ask me to format it,But instead it says
"connect the controller using a usb cable.And then press the ps button." once that is done it takes me to this part and says this "the system software cannot be run correctly.press the ps button to try to restart the system.if the system cannot be restarted.the system partition of the hard disk must be reformatted and you must reinstall the system software.insert storage media that contains update data of version 2.17 or later.and then press the start and select buttons at the same time,for more information on how to obtain update data,refer to the SCE website for your region"
I typed it all out...i pressed the button to restart it and the same thing happens and no options to format or anything...any help would be greatly appreciated.
Insert storage media that contains update data of version 2.17 or later.and then press the start and select buttons at the same time.
You can download the system updates from the $ony site and burn them to a CD."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Yeah i figured that much out but do you know if i am suppose to burn it as a data dvd/cd ect? or some other format?
nope, I get the updates directly. Their site does have directions though.
Which update should i get because i have read several errors about the new 2.40 and 2.17 seemed to be fine in the past for me...also a friend is gonna do this by memory stick so i need to get some full instructions for this so i know EXACTLY how to do this since it will be like a one chance type of thing.
2.40 is not available AT ALL. get 2.41, mine works great with it.
full instructions are on the official Playstation site."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
Use Internal Harddrive as External for ps3
By f-zer0 in forum ComputerReplies: 10Last Post: 10th Aug 2008, 18:33 -
Erasing stuff completely on harddrive on ps3?
By f-zer0 in forum ComputerReplies: 6Last Post: 21st Jul 2008, 11:32 -
How to get AVCHD on Harddrive of PS3 without loosing quality
By alex1357 in forum Video ConversionReplies: 2Last Post: 7th Jun 2008, 11:06 -
the weirdest harddrive/ripping problem ive ever seen
By ted demen in forum Newbie / General discussionsReplies: 12Last Post: 10th Feb 2008, 22:20 -
DVD--HardDrive problem
By electricsguy in forum Newbie / General discussionsReplies: 7Last Post: 24th Jun 2007, 05:14
