One of my movies is 600MB with no audio another with audio is. 1.64GB. Another is 700MB and so on. All different sizes.Originally Posted by jagabo
Results 31 to 48 of 48
I gave you my sizes. You said it depends on sizes.Originally Posted by jagabo
FRAME SIZE not FILE SIZE.
Changing the FRAME SIZE from 720x480 to 480x360 is DOWNSCALING.
Changing the FRAME SIZE from 720x480 to 1024x768 is UPSCALING. -
Oh ok..Originally Posted by jagabo
One of my movies is 640x352 at NTSC 16:9 so I change it to 854x480. Upscaling? I think I get it now.
Another is 720x404 at PAL 16:9 and size to 720x400. downscaling? -
I'm with Midzuki. 34 (35 now) posts in this pointless thread. Just stop humoring this person. Either he's terminally stupid or he's a troll.
Yes.Originally Posted by rocky12
But upscaling will not make the video look better. Upscaling will not restore or add any detail. Any time you scale digital video the quality decreases. Any time you reencode with lossy codecs like Divx/Xvid the quality decreases. You will also find that most set-top Divx/DVD players will not play anything with a width over 720 pixels or a height over 576 pixels. So you will end up with a video that occupies more drive space, looks worse, and will only play on a computer. -
So 720x768 won't playback for PAL 4:3? So I just use 720x400 instead?Originally Posted by jagabo
First note that 720x768 was a typo on guns1inger's part. He should have type 768x576. Note that 576 * 4 / 3 = 768 -- hence a 4:3 ratio.
720x768 or 768x576 will not play on most Divx/DVD players. In the first case 768 is too tall (more than 576). In the second 768 is too wide (more than 720). Some older player might attempt to play the video but give a garbled picture. Most newer players will just give an error message. -
It will, but that isn't the point.
The point is you will actually get a lower quality image by making it larger and re-encoding.
The point is you are wasting your time do what you are doing.
The point is your player will do a much better job scaling up to the correct resolution and aspect ratio on the fly than you will in software.Read my blog here.
i say no2Originally Posted by manono
php111"I'll give you five dollars if you let me throw a rock at you" -
I disagree with that last point. Most players will not do a better job of resizing than say a LanczosResize in software. But if you resize and reencode the loss in quality is permanent. If you simply play the original and let the player do the scaling you don't lose anything to reencoding and the player's loss in quality from resizing is temporary. In the future, as better resizing techniques are developed, you will see better quality from players and you won't have screwed up your original.Originally Posted by guns1inger
I like to re-encode.Originally Posted by guns1inger
I am not even going to pay attention to losers. I am doing fine learning the aspect ratio and resolutions. -
You may like to reencode but you will be losing image quality by resizing and reencoding.
This is like saying "My size 10 shoes don't fit right. Should I go to size 11 or size 9 to get a better fit?" I ask "Are the size 10 too tight or too loose?" Your reply "Will size 9 fit better? Will size 11 fit better?" How the hell should I know without some frame of reference?
Hey guns,
I just read both replies this morning but am replying now. So what your guys are saying no one knows how the resolutions are until I try them? Oh about the shoe sizes. I take bigger then size 10 and 11. Lol, I take size 12. Well probably could fit into maybe a 12 1/2 but not sure. 13 would be big and 11 would be small.
How do I scale up a video?
By Dapuma in forum Newbie / General discussionsReplies: 5Last Post: 19th Apr 2010, 07:58 -
Another VHS capture to DVD post, but cost is not really a factor
By Valnar in forum Capturing and VCRReplies: 6Last Post: 25th Dec 2008, 15:16 -
Bigger factor for blockiness/compression artifcats
By pannayar in forum Newbie / General discussionsReplies: 4Last Post: 6th Sep 2008, 07:47 -
Best Media Center Software - Cost is not a factor
By dm_0001 in forum Media Center PC / MediaCentersReplies: 10Last Post: 20th Jan 2008, 18:45 -
File Association hassle factor
By ahhaa in forum ComputerReplies: 2Last Post: 26th Aug 2007, 22:25
