I need to copy alot of dvdr-5s, have 2 burners on my PC, and would like to burn on the fly (direct from one burner to the other, not saving to the HD). What's the best freeware for this? I don't think Imgburn/Decryptor does it. I've tried Nero 6 (which works for fine for regular burns) but had mixed results with direct duplication.
Although I'm sure something like you describe exists, I haven't used any freeware application that gives satisfactory on-the-fly copy results for me. The best DVD to DVD copy software I've ever used is Alcohol 120% which isn't freeware but is available on a trial basis for evaluation and a link for download is available from this website. In addition to providing for on-the-fly copying, it also offers multiple burner support but cannot rip copy protected DVDs by itself.
If you insist upon burning directly between 2 burners, you probably need an all-SATA system (including the burners), and may have to write at the slowest speed possible to get reliable results (like at 2.4x or less write speed). But I'm doubtful that this can work very well with any software. Reading data from a DVD is typically slow, while good reliable writing to a DVD needs to have fast access to the data. That means the best way is to copy the data to your primary hard drive and write it from there, in which case you can write it reliably about 8-16x with good quality media and a fast dedicated system. By dedicated I mean you shouldn't be trying to multitask other software and jobs at the same time.
Imgburn can do it. It's the only software I use for copying on-the-fly. If you want to try it follow the instructions from the link below.Originally Posted by spiritgumm
https://forum.videohelp.com/topic322631.html#1659887
How to Burn at 16 speed or better with 4 burners
By burn master in forum User guidesReplies: 9Last Post: 30th Mar 2010, 19:49 -
Can I directly burn a DVD-R from my camcorder?
By debbyandbill in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2010, 20:17 -
Best Freeware Software to use to Burn .avi to DVD(s)
By csugal999 in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2009, 21:43 -
HELP can I transfer directly from camcorder during a live shoot to DVD burn
By Lind Lou in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2008, 12:47 -
Freeware app to burn SVCD's?
By louv68 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 18th Jul 2007, 14:28
