Is ist possible to rip the HARD DISK from a PVR and convert it to a video file using my PC, then i can burn it to DVD. Does anyone know what format the SKY+ PVR uses to store on its hard disk,
You cant convert the hard disk to a video file, the hard disk is a solid object whereas a video file is just a stream of bytes; However ; I think you know this!
Many have tried:None have succeeded. Easier just to get a dvd recorder and record to that.Corned beef is now made to a higher standard than at any time in history.
You cannot do it directly as in a simple file copy.
The only options are :-
1. connect the Sky Box to the PC with an internal or external analogue capture device and do a real time capture as the recording is playing back.
2. connect the Sky Box to a dvd recorder. Do a real time re-recording to the dvd as the original plays back. Then rip the recorded dvd disk to the PC
PVR files on a PVR formatted disk
By keithy in forum Newbie / General discussionsReplies: 2Last Post: 22nd Apr 2009, 08:26 -
Newbie with a PVR/Hard Drive Problem
By gassito in forum DVD RippingReplies: 5Last Post: 10th Dec 2008, 07:41 -
By gassito in forum DVD & Blu-ray RecordersReplies: 1Last Post: 18th Nov 2008, 01:05 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27 -
hard disc 1 died, hard disk 2 won't boot, halp!
By Yoroshiku in forum ComputerReplies: 6Last Post: 30th Oct 2007, 13:48
