I have a thirty-minute TV episode I want to convert from 200 megabyte downto 10 (or 20) megabyte, so I can share it with a long-distance friend with 40k dialup phone connection.
What's a user friendly (or even idiot-friendly) and easy way to get this done?
Thanks.
Results 1 to 10 of 10
http://www.kiva.org/about -
what format is it in to start with?
converting to a tiny .flv, like youtube videos might work, the riva encoder is free.
a better way might be to burn it to cd and mail it. it wouldn't look like crap that way. -
The container is AVI, and the video codec is XviD MPEG-4.
Yeah that's probably the best route, although I'd have to use a DVD since there are 30 of these episodes.Originally Posted by minidv2dvd -
Be sure to put the player on the DVD. Best if it can play from the DVD.Originally Posted by theavengRecommends: Kiva.org - Loans that change lives.
its going to like sh**
just up load to a file host, and let him DL to a USB device from some other PC besides his one at home -
It's Penn & Teller.Originally Posted by theewizard
It already looks like bullsh**.
Done. I experimented, and ultimately decided to go with VHS resolution which produced a blurry picture but with still-readable captions, and audio settings for FM quality. Total size == 20 megabytes. 4 episodes finished so far.
video = 81 kbit/s (320x200)
audio = 16 kbit/s (11 kilohertz peak)
overhead=8 kbit/s
total = 105 kbit/s
CODEC = Windows Media 9. I'm thinking maybe I should have used the WM8 which supposedly makes a better picture, but I guess it doesn't really matter. -
Already cut framerate to 15 fps and audio to monoaural.
I managed to get the videos downto 10 megabytes by halving the size to 160x120, but the various captions were unreadable, so I scrapped those files.
Quick question: Use MakeMKV to convert it to a streaming format?
By fatcharlie in forum Blu-ray RippingReplies: 3Last Post: 1st Nov 2011, 19:55 -
Need advice quick, 25 FLV/EXE convert to DVD
By SINBAD09 in forum Newbie / General discussionsReplies: 5Last Post: 27th Jul 2009, 06:23 -
simple and quick way to convert DVDs -> .mkv
By Helios61 in forum DVD RippingReplies: 2Last Post: 9th Mar 2009, 12:44 -
Logitech WebCam Quick Capture - How to Convert?
By deeznuts in forum Video ConversionReplies: 5Last Post: 21st Feb 2008, 10:46 -
ahh! quick! help! convert files?!?!
By lebrnjmes23 in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2008, 21:35
