    Dec 2002
    I have a now redundant SKY+ PVR and would like to transfer some of the recorded programmes on the HD disc, onto my PC, for editing and recording to DVD. can i do the following .....Connect the PVR upto my CANOPUS ADVC100 and record it to my PC using WINDV as i have been doing in the past with VHS video tapes. And yhen as usual use TMPGNC and TMPGNC DVD Author to create the DVD files.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    I don't have a Sky box but if it has S-Video out, you should be able to get your Canopus ADVC to work. Have you tried it?
    http://www.kiva.org/about
    Dec 2002
    Not tried anything yet, but I hadnt even thought about VIDEO-S ouptut, thanks for the reminder,
  4. I don't believe that Sky+ boxes have separate audio phono sockets so s-video won't be adequate (but then my girlfriend has a basic Sky box and it only has a Scart socket; no s-video). You would need a scart to red, white and yellow phono lead.
    The way that you described will work as far as I am concerned. I have the ADVC-50 and that is what I would do. Also being in Pal-land, I don't think that using the S-video route will make any difference to the quality anyway.
    I hope that this is helpful.
    Cole
    Dec 2002
    Thanks for the advice chaps, i already use a scart to phono lead for VHS conversion, so will give it a go!!
  6. Member edDV's Avatar
    Mar 2004
    While S-Video is superior, normal composite also works for the ADVC.
