I want to use this dazzle capture card, but it says I need to have a minimum of a DirectX® 9 or higher compatible graphics card with 64 MB (ATI® Radeon® or NVIDIA® GeForce™ 3 or higher, with 128 MB recommended). When I go into my device manager, it says I have a 945GM Express Chipset.
Do I have DirectX 9?
"Wanting people to listen, you can't just tap them on the shoulder anymore.
You have to hit them with a sledgehammer,
and then you'll notice you've got their strict attention."
-John Doe in Se7en -
start-->run-->type in dxdiag
that will tell you which dx version u have. -
Thanks, that worked perfectly.
-John Doe in Se7en
OpenGL and DirectX
By HotDamn! in forum ComputerReplies: 3Last Post: 6th Jan 2010, 01:00 -
DirectX
By CSULB71 in forum ComputerReplies: 4Last Post: 12th Jul 2009, 16:13 -
DirectX 9 causes black screen
By archangel2005 in forum Software PlayingReplies: 3Last Post: 13th Jun 2008, 01:23 -
How to interface with DirectX ?
By squadjot in forum ProgrammingReplies: 0Last Post: 11th Apr 2008, 22:52 -
DirectX X for XP?
By Xylob the Destroyer in forum ComputerReplies: 7Last Post: 8th Jan 2008, 17:46
