I'm running Vista Home Basic (SP1). A couple of times in the last month when I turned on my Seagate 160 HD (IDE) in my bytecc usb 2.0 enclosure I get the BSOD. I have a Seagate 320 in the same type enclosure that works fine. I've swapped both out and the same enclosure fails. It works fine on my wife's Xp notebook. The last time it happened I swapped the 320 and 160 and the problem went away.....not this time. I've also checked the usb cables and plugged into different usb ports.
Sounds like you've already narrowed it down to the one enclosure. The real question would be why it only causes an issue with the one PC. It could be a USB issue on that PC or an enclosure issue...or a combination of the two.
Google is your Friend
BSOD
By Willy5157 in forum ComputerReplies: 10Last Post: 19th Oct 2009, 14:55 -
BSOD while trying to display
By src2206 in forum Software PlayingReplies: 7Last Post: 11th Jun 2009, 13:27 -
BSOD, help would be appreciated.
By chipsndukes in forum ComputerReplies: 11Last Post: 27th May 2009, 20:06 -
BSOD when connecting printer
By alegator in forum ComputerReplies: 22Last Post: 25th Nov 2007, 16:00 -
Router, XP and BSOD - SOLVED
By Jeremiah58 in forum ComputerReplies: 8Last Post: 30th Oct 2007, 17:30
