Hello all
Forgive me if this is a common topic or is well known here, (I did try a search on the subject but got to many responses).
I've been having a problem with the video playback of certain videos in WMP and from the recommnedation of a post I made a while back here used GSpot to find out that it is a codec issue.
The one in particular is MPEG2 which is using DScaler MPEG2 Video decoder but in using GSpots test option I found several other codec's or decoders that work fine.
So my question is, how can I switch WMP to use one of those codec or decoder so I can get my proper playback again.
Preferable I was hoping there might be a program (hopefully simple one) that would let me see and test the codec and then designate it as the default one to use.
Thanks.
You would need to change the "Merit" of a particular codec to make it the default one used. You could try one of these tools at https://www.videohelp.com/tools?toolsearch=merit
P.S. This may help explain, http://msmvps.com/blogs/chrisl/pages/40395.aspx"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope"
How to change audio codec in WMV video from WMA3 to WMA2?
By hanugro in forum AudioReplies: 6Last Post: 6th Dec 2009, 22:46 -
Selecting the preferred DVD decoder/codec for WMP under Vista x64
By Dark Alpha in forum Software PlayingReplies: 10Last Post: 17th Jan 2009, 21:05 -
Combining PowerDVD 7's Audio Decoder and Microsot's MPEG-2 Video Decoder
By Dark Alpha in forum Software PlayingReplies: 4Last Post: 11th Sep 2008, 18:44 -
How to kniow which A&V decoder(s) wmp is using for my DVD?
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2008, 01:15 -
How do I change audio codec on an already burned dvd/video converted file?
By klobb in forum AudioReplies: 5Last Post: 31st Dec 2007, 05:03
