Thank you everyone for your suggestions, but it was to no avail, i tried raising that thing that webslinger suggested, but it did not work, i tried using divxfix but it didn't work either, i already have the plug-in VFAPI, and i am unfamiliar with virtual dub and cannot figure out it's controls, i normally use smart ripper>dvd2avi>tmpgenc. if anyone has any more suggestions, that wuld be great,if nt i suppose i'll just keep trying.
Thanks again everyone!
I don't see how you can use Smart Ripper with a downloaded file, but have you tried using TMPGEnc 12a ? it handles AVI's much better then any of the new versions i've encountered.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I have a great method for making avi`s to vcd. Works great for me anyway, but there are lots of ways to do this.
First u decompress the avi with the program "avi2vcd" under "decompress", then u get a file named for example Shrek.avi_pcm. This file is much bigger than the ordinary file. Then you just convert it to vcd with TMPGnc; once u have done this the file is about its ordinary size.
Make sure that u have all the latest codecs.
If this don`t work you`ll have to choose higher priority to "Directshow multimedia file reader" (I have priority 5 on this one, zero on all the others except from "avi vfw compability reader that has -2)
You can do all this under "environmental settings" In the VFAPI plug-in section.
Hope this can help
Christer
scorpions are the kings!!
Script redirects to website when opening a downloaded AVI file.
By B Nasty in forum Newbie / General discussionsReplies: 15Last Post: 5th May 2010, 06:01 -
Can't transfer .avi file from camera...
By Captain Satellite in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:32 -
no sound with newly downloaded .avi file
By JediPM in forum MacReplies: 7Last Post: 30th Dec 2008, 16:29 -
I have downloaded file clips in .divx how can I convert to .avi?
By Ricksasha in forum Video ConversionReplies: 8Last Post: 13th Nov 2007, 14:36 -
AVI File Downloaded from torrent
By mps in forum Video ConversionReplies: 1Last Post: 10th Jun 2007, 11:54
