I orginally have an AVI file and I used AVI Mux to Mux the video and audio and it made it as a MKA file. How do I take that MKA and turn into AVI? I never heard of MKA before. I have heard of MKV. I tried loading the MKA into VirtualDub and VirtualDubMod but it is unsupported. When I have the AVI, it loaded fine into Dub.
Results 1 to 30 of 49
Question 1 : Why change a perfectly good AVI into an MKV file ? You gain nothing.Originally Posted by rocky12
Question 2 : Have you tried changing the file extension MKA to MKV ? AVIMux GUI makes no mention of MKA, so I am assuming it is a typo on your part somewhere in the process. Simply chanhge it to MKV and chance are high it will play.
Question 3 : Where is the original AVI file ?Read my blog here.
The .mka extension was set aside for audio-only Matroska files, as I recall - but I've never seen anyone create those, until now.
If cameras add ten pounds, why would people want to eat them? -
Question 1. I didn't want MKV. I wanted AVI.Originally Posted by guns1inger
Question 2. I figure it but but even with AVI Mux, I still get synch problems. The audio is off.
Question 3. It's on my hard drive. -
So lets go back to basics. You have an AVI file. You ran it through AVI Mux and ended up with a format you didn't want, and a file with audio sync problems. You want the file to be an AVI file, which you already have.
What is wrong with the source avi that lead you to use AVIMux on it ?Read my blog here.
Because VirtualDubMod was giving me synch problems first when trying to Mux so then I tried AVI Mux and thought that will work but I was wrong. Right now, I have a second pass DivX with no audio. If I Mux together then I get synch problems.Originally Posted by guns1inger
What sort of sync problems ?
What sort of audio ?
If the audio is out by the same amount all the way through then you have a simple delay problem. All you have to do is work out what the delay is, adjust for it in virtualdub, and save a new file.Read my blog here.
I don't get it; or you are not giving the entire story.
You already have an .avi video. What are you trying to do to it? What are you trying to Mux? What is the source of your 2nd audio ? What is your original audio format? original video format? use mediainfo if you don't know.
If you provide more information you'll get better answers -
The audio is too late and it's CBR MP3. It was original AC3 but I used Lame to encode to MP3. How do I work out the delay? I don't know how many ms do I set?Originally Posted by guns1inger
The original was DVD with AC3 encoded at 192kbps. I encoded it too MP3 CBR at 192kbps. There are multi audio. 3 audio files. I encoded to DivX with multipasses.Originally Posted by poisondeathray
I'm assuming you want single track .avi, and that you selected the proper one.
Just use avidemux, under the audio sidebar shift tick, and enter +/- delay (e.g. -1000ms). You can play to preview if in sync on the fly, adjusting until it's right.
Leave the video set to copy, audio set to copy, format set to avi
Press save with extension (e.g. "myfile.avi")
This only works if it's a constant delay problem. If the delay worsens with progression, you have to shrink/expand the audio to fit the same duration of the video. If this is the case, come back and tell us -
Huh? I don't know how much delay ms should I set? I am not good at guessing like that............Originally Posted by poisondeathray
1sec = 1000ms
You can preview it. If it's too slow, enter a different value...not that hard.. then change it to 1500ms...you get the idea LOL
All it's doing is shifting the audio track -
Is there a different way? Is there a way I can encode to MP3 WITHOUT synch? I am not setting no delay. With my luck it be way off.Originally Posted by poisondeathray
Yeah you could encode it properly the first time. How did you rip the dvd and encode the avi?
BTW, this audio shift is VERY EASY to do. Takes about 1minute to fix a video. You could have fixed it by now
Sometimes the problem is the video (e.g. if it's encrypted and you didn't decrypt it properly) - I'm assuming your original source was a DVD?
When you use DGindex, it will tell you the delay on the AC3, it will say something like "FILENAME..DELAY 72ms.AC3". That is the number you put in 72ms. If audio is too late, you want a negative delay to shift the audio earlier
If this truly is a constant delay problem (not the different length problem like mentioned earlier), the avidemux solution will fix it in a few seconds. Seriously, my 10 year old cousin could do it - it's that simple.
Just try it. You will kick yourself when you see how simple it is... -
They are all 0ms. All 3 audio files are 0ms.Originally Posted by poisondeathray
This is ridciolus.....It's getting worse as I am going along. -500 I tried and it was still off so I tried -400 and it's getting worse......err now I have to chew on some Skoal cause my nerves are shot.........
poisondeathray,Originally Posted by poisondeathray
How can I fix the synch? I tried fixing it using VirtualDubMod and it didn't work. I don't know how to use AVIDeMux. -
I gave you step by step instructions already...just enter a value, press play, adjust it e.g. -400ms then press play, if still out of sync, enter a new value e.g. -300ms etc...press play...
Originally Posted by poisondeathray -
I loaded in my video but how do I load in my audio tracks?
audio=>main track and choose external mp3 or ac3 or whatever you want. I'm assuming you only want single audio .avi
FYI you could do the entire conversion with this tool as well (VOB=>AVI) -
Don't load the non-english track. Only load 1 audio fileOriginally Posted by rocky12
Is it closer or worse to being in sync? Try a different value like -400, press play. If it's worse, try -600. You said audio is late right? Just do it on the fly (don't save until it's correct). -
The audio won't play if it's on the fly. Only the video will play.Originally Posted by poisondeathray
You mean non a different language. You said non English. I want English. Lol. -
I said: "don't load the non english track"
Translation: load only the english track, not other stuff
Is it better or worse? try a different value until it syncs up. You haven't said anything about this. If you want answers provide more info.
Remember this only works for the constant delay problem...which you haven't verified yet
[SOLVED] How to tag an mkv/mka file?
By bat999 in forum Newbie / General discussionsReplies: 13Last Post: 24th Jun 2018, 15:20 -
Used mkvtoolnix and need help making audio from mka to ac3 Major help pleas
By csta in forum AudioReplies: 10Last Post: 2nd Aug 2017, 11:03 -
Need help as mkvtoolnix extracts dts audio as mka and ineed it as ac3 help!
By csta in forum MediaReplies: 1Last Post: 12th Aug 2011, 03:17 -
Need to change AVI to WMV!
By jason_in in forum Video ConversionReplies: 3Last Post: 28th Nov 2007, 11:56 -
Avi change brightness
By Digiface in forum EditingReplies: 4Last Post: 9th Aug 2007, 18:15
