I have one file encoded in XVID that for some reason can't be streamed to my PS3. My other XVID files work perfectly fine. What's the problem? Weird that its only one file. Could it be a frame rate problem, or a FOURCC problem, or a problem with my ps3? I read somewhere else where there was problems streaming xvid to the ps3 using windows media player 11 but no problems in tversity.I am using TVersity v. 0.9.11.4 that streams using the DLNA protocol. Well, here is the info on the file I'm trying to stream.
Open the file with g-spot or media info. They will tell you a lot more about the file than virtualdub will. Look for things like VBR audio, packed bitstreams, or the use of GMC and qpel
Read my blog here.
Maybe just run it thru vdub to "correct" any errors in it and to rewrite the header. It may be just a single stray byte thats stopping it playing?..Failing that you'll have to call the VSI squad.
The electronic components of the power part adopted a lot of Rubycons.
Any software that can stream to PC and PS3 on a LAN simultaneously on XP
By gll99 in forum Video Streaming DownloadingReplies: 5Last Post: 24th Jul 2010, 18:09 -
Rip DVDs to my HD so that I can stream them to my PS3
By joegeis in forum Newbie / General discussionsReplies: 18Last Post: 11th Oct 2009, 18:47 -
Got ripbot working, BUT it wont stream to my PS3
By Fiostech in forum Blu-ray RippingReplies: 5Last Post: 5th Feb 2009, 13:15 -
Blu-Ray rip and stream to PS3
By bytre in forum Blu-ray RippingReplies: 2Last Post: 26th Mar 2008, 20:15 -
Xvid stream to PS3
By Sooner02 in forum Media Center PC / MediaCentersReplies: 5Last Post: 2nd Jan 2008, 13:44
