Is there any way to create a DVD with TMPGEnc DVD Author 3 so that it plays back on a television without overscan . . . so the borders do not appear to be cut off? Thank you!
Read my blog here.
Thanks. I wish I knew more about these programs (especially since they're free). In time, I'll do some reading & see if I can figure them out. Thanks for pointing me to them.
I have tried using avisynth through FitCD as suggested, with my TMPGEnc Xpress but TMPGEnc can't handle it. It keeps cutting the video off and all you see is a black screen with something like a red X. This happens after about 1/6 into the episode.
What might I be doing wrong, and is there other ways to adjust for overscan encoding with TMPGEncXpress?
Edit: I should also mention that this is the pre-encode to convert it into an MPeg file before I can use Author and convert the MPEGs into DVD Vobs.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
Sound turned to white noise when using TMPGEnc Xpress & DVD Author
By Hal05154 in forum Authoring (DVD)Replies: 4Last Post: 15th Jan 2009, 22:03 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 02:40 -
TMPGEnc DVD Author & Dolby 5.1 Digital Sound - Can it be Done??????
By Sparehead01 in forum EditingReplies: 2Last Post: 28th Dec 2007, 14:53 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
