I am looking for a freeware dvd authoring tool to combine different video files (avi, divx, wma etc) and create a video only dvd to be played on $30 DVD player purchased from the supermarket nowadays. This will be used to collect several different family member contrbuted video and be distributed to grandmas and grandpas without computer access.
Thanks for all your suggestions and help in advance.
Thank you for the fast response. Now I selected my videos and creating the DVD folder on the background. Now comes the second part of that question, what is a freeware dvd burner program which will take the FAVC output dvd folder and burn it to a blank dvd without much fuss ?Originally Posted by olyteddy
Thanks again in advance. -
Well, my first dvd got created fine but when I come to an about 2 hours long wedding video, which I am able to watch using VLC player and/or Windows media player, says can not open this video file because either the codec is not installed or Avisynth level is below the 2.5.7. I downloaded and installed avisynt 2.5.7 just before installing FAVC after reading the installation prerequisites. I made sure that I have the right codec installed. I used Gspot and and found out that AVI file was encoded as divx format and gspot says the codec is installed.Originally Posted by olyteddy
What do I need to do so that FAVC can recognize this video file ?
simple freeware tool
By agent222 in forum Video ConversionReplies: 3Last Post: 1st Oct 2010, 16:22 -
Searching Freeware for DVD-AVCHD (mini Blueray) Authoring
By benji179 in forum Newbie / General discussionsReplies: 5Last Post: 30th Mar 2010, 14:17 -
Found an excellent freeware DVD copy tool...
By Djard in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2008, 20:17 -
is there a freeware tool for making an image of my c drive?
By surfmonkee in forum ComputerReplies: 17Last Post: 10th Nov 2007, 21:01 -
What is the best freeware tool to convert a DVD to iPod?
By xoADAMox in forum Newbie / General discussionsReplies: 6Last Post: 8th Jun 2007, 22:18
