i am trying to rip a dvd on to a vcd,i use smart ripper to rip and then i use dvd2avi,then when i go to use tmpgenc,i can input the audio file,BUT WHEN IT COMES TO THE video file,it says cannot open or unsupported,what am i doing wrong,its driving me looney.
i am doing everything the vcdhelp guide tell me,.
PLEASE HELP ME,cause they r going to lock me up,im going ga ga ere.
thx
go on give a newbie a chance
what is the file extention? it should be a .d2v file after using dvd2avi. if not check your settings in the dvd2avi program and make sure the are the same as the guide you are following.
yes it is a .d2v file,tmpgenc wont open it,how do i convert to a AVI file?
go on give a newbie a chance -
here....try this 8)
http://gknot.doom9.org/Software/GordianKnot.0.21.Setup.exe
it is pretty cool and is for newbies like you and me -
many thxOriginally Posted by D3LtAg3Kogo on give a newbie a chance
Make sure the *.d2v file is the one written by DVD2AVI and not the one written by Smartripper.
VOB files reporting wrong playing time
By awgie in forum Newbie / General discussionsReplies: 23Last Post: 18th Mar 2021, 07:32 -
[DVD Lab Pro] subtitles wrong time
By dom61 in forum Authoring (DVD)Replies: 2Last Post: 4th Sep 2011, 08:42 -
iTunes 8 displaying a few songs with the wrong run time
By Nintendo Fan in forum ComputerReplies: 26Last Post: 8th Jul 2009, 19:34 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
