    Jul 2008
    Title says it all basically.
    Thanks.
  2. FAVC - free
    ConvertXtoDVD - trialware
    Jul 2008
    Thanks.
    If you don't mind, i have another nub question ^^
    I wanna burn a full DVD's capacity full of episodes i have. Will there be a way to select which ones i want to play when i load it into my DVD player connected to my TV? ... how does that work?
  4. Yes, both the programs above create simple menus and author the DVD structure for you. So you just pick the episode you want once you've burned the DVD.
    The more episodes you put on a DVD, the worse the quality.
    canada
    More than 4x30 minute programs will start to look worse on one dvd.8x30 minutes if you want to put on dual layer dvd.
    Jul 2008
    Thanks again.
    One more thing. I run on a mac platform. Do you know of any apple equivalents that will accomplish the same thing?
    Jul 2008
    I hate to keep bombarding you will nub questions...
    I was able to convert .rmvb to .mp4 to mpeg-2 DVD. If i just take that file and burn it onto a DVD will that work? or is DVD burning software necessary?
