Can someone answer these questions about the Quicktime .mov format
How does Quicktime compare in video image quality with mpg2 video?
Can Quicktime files be converted to .mpg2 files without significant loss of video quality?
Is there a good video software editing program that can edit Quicktime videos?
Thanks for your help!
mov is a container.
(that sucks)
quality is defined by what's actually in the container.
lisi"I'll give you five dollars if you let me throw a rock at you" -
mov can be equally as good as mpeg2. It is an apple version of mpeg4 so is newer than mpeg2, so inevitably it has better compression. Tmpgenc will handle mov's converting them to mpeg2 (Same quality, larger file size).
Apple Ilife will edit mov.
mov's will not eat your clothes.
Try this Link I specially made for you
https://www.videohelp.com/tools?toolsearch=&Submit=Search&s=&orderby=Name&hits=50&conve...uthorfeatures=Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
Rendered MP4 Files - Video but no audio in Quicktime on different PC
By pauldsc in forum Software PlayingReplies: 1Last Post: 5th Nov 2011, 09:24 -
Some questions about QuickTime Pro
By VidHunter in forum MacReplies: 1Last Post: 8th Jan 2009, 12:04 -
How to Convert Quicktime MOV Video Files to MPEG-2
By hiroprot in forum Video ConversionReplies: 8Last Post: 10th Nov 2008, 09:54 -
Extracting audio from video files (Other few questions)
By Mickz in forum Newbie / General discussionsReplies: 14Last Post: 25th Feb 2008, 14:47 -
Two Quicktime Questions
By amoseman in forum MacReplies: 4Last Post: 29th Dec 2007, 05:13
