I extracted the .h264 and .aac files from a .mp4 file and thought I could mux them to an avi with this avi muxer I have but apparently I can't do that. What do I need to do with a .h264 file to get it able to be muxed into an .avi? Or do I need to convert it to some other format first?
Now, I have downloaded a number of free video conversion programs that were listed in the video converison forum on how to convert .mp4 to .avi xvid/dvix, so I probably don't need to know what to do with a .h264 file. However just for future reference, what does one do with a raw .h264 file extracted from .mp4 to get it into a .avi file with aac or mp3 as audio?
.h264 is not completely compatible in .avi container. You get B-frame lag (if it was encoded with B-frames), and will experience playback problems on many players
Use YAMB to put it into a .mp4 container, or mkvmergegui to put it in a .mkv container
If you must use an .avi container (WHY?), you should probably re-encode it without B-frames (you will lose quality since it's a lossy codec) -
If you're playing on a PC, you don't need to convert. VLC can play MP4 files fine. If you have a standalone DVD player that supports Divx/Xvid, it still won't play the file even if you could get it in an AVI container. AAC audio is also bad for standalone DVD players.
You can convert to Divx (I guess this is what you really mean by "AVI") with various tools such as AutoGK and Dr. Divx. -
Well yea Divx or Xvid but I need in in an avi container and nothing else, so I had to say avi, heh.Originally Posted by jman98
I've downloaded most of the free video converters on this site but haven't gotten around to using them yet. I'll try them out. Thanks.
Need to batch (or queue) convert raw h264 file to mp4
By dukestravels07 in forum Newbie / General discussionsReplies: 10Last Post: 29th Mar 2015, 12:45 -
muxing raw h264 with raw g711 to mp4 continer
By niror in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2011, 12:25 -
MKVextractGUI: extracted video result in .h264 format instead of .mp4
By shichi00 in forum Video ConversionReplies: 1Last Post: 19th Mar 2010, 04:28 -
Mux h264.mp4 into avi container?
By ayim in forum Video ConversionReplies: 4Last Post: 11th Feb 2010, 07:18 -
How to create .mp4 file by using raw .h264 and .aac files for JW Player
By hakkinen in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 21:49
