i have problem with seeking file, when i use -ss i have segmentation fault
source file
MPlayer dev-SVN-r26753-4.1.1 (C) 2000-2008 MPlayer Team
CPU: Intel(R) Xeon(R) CPU X3230 @ 2.66GHz (Family: 6, Model: 15, Step ping: 11)
CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2
Playing ../*****/****.
ID_VIDEO_ID=0
ID_AUDIO_ID=128
MPEG-PS file format detected.
VIDEO: MPEG2 704x576 (aspect 2) 25.000 fps 9554.8 kbps (1194.4 kbyte/s)
ID_FILENAME=../*****/*****
ID_DEMUXER=mpegps
ID_VIDEO_FORMAT=0x10000002
ID_VIDEO_BITRATE=9554800
ID_VIDEO_WIDTH=704
ID_VIDEO_HEIGHT=576
ID_VIDEO_FPS=25.000
ID_VIDEO_ASPECT=0.0000
ID_AUDIO_FORMAT=8192
ID_AUDIO_BITRATE=0
ID_AUDIO_RATE=0
ID_AUDIO_NCH=0
ID_LENGTH=2529.33
ID_SEEKABLE=1
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 704 x 576 (preferred colorspace: Mpeg PES)
VDec: using Mpeg PES as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
VO: [null] 704x576 => 704x576 Mpeg PES
Selected video codec: [mpegpes] vfm: mpegpes (MPEG-PES output (.mpg or DXR3/IVTV /DVB/V4L2 card))
ID_VIDEO_CODEC=mpegpes
Opening audio decoder: [liba52] AC3 decoding with liba52
Using SSE optimized IMDCT transform
Using MMX optimized resampler
AUDIO: 48000 Hz, 2 ch, s16le, 256.0 kbit/16.67% (ratio: 32000->192000)
ID_AUDIO_BITRATE=256000
ID_AUDIO_RATE=48000
ID_AUDIO_NCH=2
Selected audio codec: [a52] afm: liba52 (AC3-liba52)
[AO OSS] audio_setup: Can't open audio device /dev/dsp: No such file or director y
[AO ESD] esd_open_sound failed: No such file or directory
DVB card number must be between 1 and 4
AO: [null] 48000Hz 2ch s16le (2 bytes per sample)
ID_AUDIO_CODEC=a52
Starting playback...
a52: CRC check failed!
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
ID_VIDEO_ASPECT=1.3333
VO: [null] 704x576 => 768x576 Mpeg PES
A: 1.5 V: 1.5 A-V: 0.019 ct: 0.012 34/ 34 0% 0% 0.3% 0 0
command
mencoder ../source -ofps 25 -o file.flv -of lavf -oac mp3lame -lameopts br=128 -srate 44100 -ovc lavc -lavcopts vcodec=flv:vbitrate=700:mbd=2:mv0:trell:v4mv:cbp:l ast_pred=3redia=2:dia=2:vmax_b_frames=0:vb_strategy=1
recmp=2:cmp=2
ubcmp=2
reme=2:qns=2 -vf scale=520:296 -ss 1174 -endpos 180
MEncoder dev-SVN-r26753-4.1.1 (C) 2000-2008 MPlayer Team
CPU: Intel(R) Xeon(R) CPU X3230 @ 2.66GHz (Family: 6, Model: 15, Stepping: 11)
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
success: format: 0 data: 0x0 - 0xb40f5000
[V] filefmt:2 fourcc:0x10000002 size:704x576 fps:25.000 ftime:=0.0400
** MUXER_LAVF ************************************************** ***************
REMEMBER: MEncoder's libavformat muxing is presently broken and can generate
INCORRECT files in the presence of B-frames. Moreover, due to bugs MPlayer
will play these INCORRECT files as if nothing were wrong!
OK, exit.
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=520 h=296]
The selected video_out device is incompatible with this codec.
Try appending the scale filter to your filter list,
e.g. -vf spp,scale instead of -vf spp.
VDecoder init failed
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffmpeg2] vfm: ffmpeg (FFmpeg MPEG-2)
MP3 audio selected.
Flushing video frames.
Filters have not been configured! Empty file?
Writing index...
Writing header...
Segmentation fault
i can seek by using -sb but have audio delay.
you should post a bug report when getting seg faultsOriginally Posted by Jeje"I'll give you five dollars if you let me throw a rock at you"
Mencoder // ffmpeg flv file Audio-video sync problem
By krishnareddy in forum ffmpegX general discussionReplies: 5Last Post: 26th Apr 2009, 09:13 -
Mux a FLV AVI + MP3 -> FLV with ffmpeg or mencoder?
By Colmino in forum Video ConversionReplies: 9Last Post: 29th Mar 2008, 22:11 -
AVI to FLV using mencoder
By Riotblade in forum Video ConversionReplies: 11Last Post: 13th Feb 2008, 12:00 -
Problem converting MPEG2 to FLV with MEncoder
By mspo in forum Video ConversionReplies: 2Last Post: 1st Jan 2008, 08:44 -
Mencoder converting Anything to FLV.
By Caliber Mengsk in forum Video ConversionReplies: 3Last Post: 13th Jul 2007, 17:30
ubcmp=2
