Hi guys
I just got a generic mp4 player which seems to lose audio sync on almost every avi file I try (including files that play perfectly on my PC).
There are a couple of xvid files that I've tried which do play properly, but I've been unable to replicate this in any of the files that I've encoded myself. I've tried to use the same codec, copy the audio and video bitrate, and everythinig else I could find.. but it's still not working.
Can anyone recommend some software that will tell me the exact parameters used in a file for every configurable variable in an xvid avi.. and will then let me configure those parameters in my own encoding?
The two files that i found that WERE WORKING used VBR audi.. but I can't get virtualdub to encode using vbr. Can you recommend some software?
If the working files were using VBR audio (I'm assuming MP3), then the player surely can play CBR audio - in other words that's not the problem.
If you still wanted to fiddle with the audio, you need to have lame acm codec installed, and audio in full processing mode. You can choose ABR or VBR. Leave video as direct stream copy. Note you can only output into .AVI container with vdub. If you wanted .mp4 container, use avidemux (you said .mp4 player, but I don't know if it supports .avi). Another option is to use LameXP to process your audio to VBR or CBR - again I doubt audio is your problem
Post screenshots of GSPOT from working and not-working files. It probably has to do with B-frames, or packed bitstream.
What are the exact requirements for a video to be AVCHD complaint ?
By ahmadka in forum Authoring (Blu-ray)Replies: 4Last Post: 1st Jun 2011, 20:24 -
!!! Exact Audio Copy 99,99% enough? Parameters OK?
By flashandpan007 in forum AudioReplies: 14Last Post: 13th Feb 2011, 09:51 -
xmedia Recode - Where can I find these enconding parameters?
By TYLER08027 in forum Video ConversionReplies: 3Last Post: 6th Nov 2010, 15:40 -
How to check the exact video bitrate in Kbit/s
By BassJunkie in forum MacReplies: 2Last Post: 15th Aug 2008, 12:31 -
re-encode while keeping the exact number of frames
By bt04 in forum Video ConversionReplies: 16Last Post: 25th Feb 2008, 20:21
