Hello i 've being converting a quicktime movie file to 3gp, encoding...and etc went well and the Clp was converted but there was a slight problem with the video..It was mirrored![]()
Is there any solution to fix this problem?
1/ Try selecting the Decode with QuickTime checkbox in the Options tab. That makes ffmpegX use QuickTime to read (decode) (the video of the) files, so it should know left from right in the same way as QuickTime Player. Decoding with ffmpeg was 3% faster than decoding with QuickTime on my test clip.
2/ Or: try MPEG Streamclip as an alternative converter to 3gp. It uses QuickTime to read (decode) files, so it should know left from right in the same way as QuickTime Player. If it doesn't, it also features a "flip" option to mirror the video (back) if needed.
problem with 3gp video
By flyingfrogsss in forum Newbie / General discussionsReplies: 1Last Post: 22nd Aug 2010, 04:56 -
Convertng DVD to WMV with AutoMKV - Output Resolution confusion
By mobon in forum Video ConversionReplies: 3Last Post: 16th Jan 2010, 07:17 -
Converting AVI (DivX/XviD) to MP4/MOV/3GP...
By JaleAlbatros in forum Video ConversionReplies: 5Last Post: 23rd Jul 2009, 17:51 -
3GP Converter problem
By EliteMarine in forum Video ConversionReplies: 2Last Post: 9th Jul 2008, 19:23 -
3gp conversion problem
By nddcndndd in forum Portable VideoReplies: 5Last Post: 20th Oct 2007, 13:15
