What is the difference between Full Processing Mode and Fast recompress for video encoding? What is more slower?
Full processing is taking one format and converting it to another.
Fast recompress is just basic editing and saving in the same format.
I assume you are looking into Virtualdub as a first time user as this is their terminology. Check the guides on the left of the screen for more information on virtualdub.
Also you can check out the glossary on the left of the screen for more techinical answers - mine is kind of a generic description.
https://www.videohelp.com/glossaryDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Lots of differences. You'll need to use Full Processing if intending to use the VDub filters. It'll also convert your source to RGB first. With no filtering you can use Fast Recompress. I think that's right.
However, since most people need to filter their videos somehow, at least with a resize, they have to use Full Processing. If speed and quality are important, much better would be to frameserve into VDub(Mod) with an AviSynth script with the filtering already done. Then you can use Fast Recompress. The result - up to 30% or so faster encoding and better quality. -
Fast Recompress Mode simply passes the video through to the encode without altering the colourspace or changing the video in any way. Think of it as Direct Stream Processing without the edits.
Full Processing Mode shifts colorspace to RGB, even if you don't use any filters, and causes a performance/speed hit as well as risking introducing artifacts and colour changes.Read my blog here.
Does BD-Rebuilder Full Disc mode work?
By ronorkis in forum Blu-ray RippingReplies: 22Last Post: 1st Sep 2009, 05:12 -
Full Backup Mode in BD Rebuilder
By fjmr in forum Authoring (Blu-ray)Replies: 2Last Post: 25th Jul 2009, 03:32 -
Full screem mode
By sat-jokar in forum Video ConversionReplies: 3Last Post: 29th May 2009, 08:36 -
fast recompress in avidemux?
By Holonet in forum LinuxReplies: 1Last Post: 28th Jan 2008, 10:16 -
Problem "Full processing mode" in VirtualDub
By jonaskarlsson in forum AudioReplies: 11Last Post: 11th Aug 2007, 21:30
