I'm following the steps and tools outlined here:
https://forum.videohelp.com/topic346331.html
But having strange problems; the *.bat isn't working for me.
I don't get 5 files (with the critical *.avs file I need), just 2 files are created: bits0001.mpa and bits0001.mpv
I've tried multiple versions of AVCHD_convert files (v5, v5 vimeo, etc.) and with multiple *.m2ts files, but still getting only the two *.mpa and *.mpv files.
Any idea what's wrong?
	1) Do your files have a .MTS extension ? That's required for the batch file to work.
 2) Would you upload a short clip of your source file? You can use http://www.mediafire.com
	Thanks for the offer to help, Soopafresh. I actually think I figured it out.
 I tried a smaller clip (20 Mb), and it worked.
 With larger files (200+mb), I don't think I was giving the computer time to do its thing. The DOS window opened and showed no activity, so after 30 sec or so, I would close the window. However, if I wait long enough, it continues thru the process and makes the 5 files.
 I think I am good now. Thanks again for your offer to help.
  Help me join these two .bat files...By CactusMan in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2012, 14:08
  Bat file not looping?By sambat in forum ComputerReplies: 5Last Post: 26th Feb 2011, 15:58
  Need a .bat file to join avi filesBy aat666 in forum Newbie / General discussionsReplies: 2Last Post: 7th Oct 2010, 07:46
  Help with these commands - VC1 ASF2VC1 .bat.....By tigerb in forum Newbie / General discussionsReplies: 4Last Post: 2nd Feb 2010, 19:01
  get FPS value from mediainfo into a bat scriptBy ricardouk in forum ProgrammingReplies: 1Last Post: 10th Nov 2009, 10:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
