Can someone tell me how to extract or use BIN files? thanx
Results 1 to 9 of 9
use cdmage to extrack bin files
or
burn the .cue file included with Nero by choosing "Create from Image File" options. -
ok the problem is I dl a movie and its in a bin format. I use nero and "burn image" and then pick the bin file ... then type of image is set to "Data Mode 1" then "block size" 2048... but that turn out to be to large for a CD... then tried "block size" 2352 and Raw was check automatically. and burn image... it didn't play...
can someone help? -
You can use Nero, but my experience is that it doesn't always burn successfully.
You can burn CUE/BIN images with the following proggies like so:
http://www.geocities.com/medinotes/vcd/burning_cuebin_images.html
http://www.vcdimager.org/guides/burning_cuebin_images.html (mirror)
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 01:02 -
recover files from recycle bin
By Tbag in forum ComputerReplies: 5Last Post: 25th Jul 2008, 07:16 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
