    Jul 2008
    Hi,
    I am using WINDVR for capture from my tv tuner card. I am trying to write an app of my own and am using graphedit to create my graphs. I have a problem. I have a graph that works fine when windvr has been launched. but when i first logon and try to run the graph i get a black screen. When i go back view my graph i have lost connections. The connection between my crossbar and capture codecs, and the connection between my capture and audio renderer codecs are lost. I am new to graphedit. When i created the graph the capture box was highlighted in orange. Not quite sure if this means anything. Any thoughts would be greatly appreciated.
  2. Member Soopafresh's Avatar
    Jan 2004
    Only thing I can think of which might help you on the programming side is this application:
    http://www.thedeemon.com/GraphEditPlus/
    Jul 2008
    Thanks for the prompt reply. Let me see if this helps me.
