Hi there folks,
some videos wont start when I use subtitle files. If I delete/remove the subtitle file from the folder, the video works fine. I have installed vobsub 2.23 and most of hte videos are no problem.
Is there a codec missing?
I cant figure out whats wrong. Hope someone can help, I really like WMP.![]()
Thx for your reply Baldrick, but still the same problem
What is most likely the problem? Codecs? FPS? Bit rate? -
It wouldn't be a codec if the file plays fine without the subtitle. Most likely, the subtitle file is corrupt or just in a non standard format.
Google is your Friend
Crop videos playing on Windows Media Player
By kingshay in forum Software PlayingReplies: 2Last Post: 28th Nov 2010, 13:00 -
Media Player Classic (Subtitle Problem) !
By Bahez in forum Software PlayingReplies: 1Last Post: 2nd Jan 2009, 07:19 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
How to download videos from embedded windows media player?
By andrea:) in forum Newbie / General discussionsReplies: 1Last Post: 12th Dec 2007, 05:03 -
Windows Media player problem
By Super Warrior in forum ComputerReplies: 3Last Post: 17th Nov 2007, 14:20
