Like most of us looking for a way to save a buck these days, I stumbled upon this website that offers a way to modify your engine to use water in order to enhance your MPG by a high percentage. I've tried to locate reviews (unbiased of course) but every review I've found has a link to buy the system from them in the end...
It seems "reasonable" to me, but then again, every scam does in the beginning.
Is it possible?, is it worth the money/effort?.
Do you know somebody using it?.
http://water4gas.com/2books.htm
(BTW the "AS SEEN ON TV" sign scares the crap out of me as they sell crap that never works...)
1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
I'd rather learn how to build a vimana by my own hands.
"AS SEEN ON TV!" should say it all. -
Take a look at Oxyhydrogen.
Consider that you are burning gasoline to power your car, including your alternator. Now take the output of your alternator and electrolyse some water into HHO (aka, Oxyhydrogen or "Brown's Gas").
Next burn the Oxyhydrogen as fuel to power your car and electrolyse more HHO.
Then, consider the Laws of thermodynamics and Conservation of energy. Now do you see the problem?
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
Water damaged tapes
By NightFire in forum RestorationReplies: 2Last Post: 22nd Jan 2011, 23:58 -
Are water-shield discs necessary?
By SilverBlade in forum MediaReplies: 24Last Post: 24th Feb 2009, 21:40 -
BTF part 3 question - why not use gas from the second delorian????
By yoda313 in forum Off topicReplies: 14Last Post: 26th Jul 2008, 20:09 -
water cooling systems
By romanstopme in forum ComputerReplies: 18Last Post: 29th May 2008, 10:12
