I have about 60 different OGM files with external SSA subtitles. Each OGM has 2 audio streams (English and Japanese).
What I want to do is convert them to RMVB but since I haven't found a direct converter for that, I'm using AllToAVI v4 r5394 to convert to AVI and then to RMVB.
This is not the problem though.
I have used the batch convert option ('Add Folder') in AllToAVI and these are the conversion options I have used:
Each file took about 3-5 minutes and the video and audio quality were the same as the original OGM file (this was what I wanted).
BUT, only 31 out of the 59 files converted successfully. There were no error messages or anything. Just the output size of the 28 unsuccessful conversions were under 100MB and ended after some minutes (the originals were ~20 min. - all unsuccessful conversions were <10 min. long).
Any ideas why this happened?
Results 1 to 9 of 9
been a long time since i tried alltoavi
don;t know how it's come along,
but i didn;t like it back then.
i changed ogm2avi a bit
https://forum.videohelp.com/topic334918.html#1739038
in drag and drop style,
but you can change it to batch a folder.
could poossibly do it with ffmpeg too.
my build though
you could also halt mp3 conversion.
no point in going vorbis->pcm->mp3->realaudio
unless HD space is an issue.
and if the realvideo converter took avs input,
you could avoid avi creation.
tripp"I'll give you five dollars if you let me throw a rock at you" -
I tried it and it worked fine until it got to the AVImux stage. Once it opened AVImux, the window kind of froze and after about 5 seconds, the window closed and all of the Temp files were deleted. I used the OGM2AVI-A2.bat file.
OK. After some tweaking of the batch file I have got it to work. How do I change it to batch a folder?
Originally Posted by m93
it was already in working order.
i'll update the guide with this:
ogm2avitweak.zip
ogm-a1, ogm-a2, ogm-dual
place ogm files in the same solder as the batch files.
double click one.
renamed previous batch files to have DND prefix. ,
drag and drop.
create shortcuts of them, place them anywhere,
drag and drop one file at a time.
oh and as you were using a2,
and are using the avi as an intermediary,
i did a version of it to mux the video with uncompressed audio,
rather than compress to mp3.
put the batch file with the rest.
ogm-a2wav.bat
I had to tweak it because I was using SSA subtitles. I kind of combined your version and the original because for some reason, the batch file didn't work. It is like this now:
Code:@Echo Off If x%1x==xx Exit Cls Copy /Y %1 Temp\Temp.ogm OGMDemuxer\OGMDemuxer -a Temp\Temp.ogm Del Temp\Temp.ogm OGGDec\oggdec -o Temp\Temp.wav Temp\Temp_2.ogg Del Temp\Temp_1.ogg Del Temp\Temp_2.ogg LAME\LAME -b 112 -q 2 Temp\Temp.wav Temp\Temp.mp3 Del Temp\Temp.wav avimux\AVIMux Temp\Temp_0.avi Temp\Out.avi Temp\Temp.mp3 Move Temp\Out.avi %1.avi Del /Q Temp\*.* Exit
What do I have to change in the batch file to make it convert a folder? -
Never mind the last post. I just had not read the instructions carefully. It's working fine now.
Thanks for the help.
Converting OGM files to AVI/MPEG with subtitles
By StevoK in forum Video ConversionReplies: 1Last Post: 4th Feb 2010, 01:50 -
converting OGM/MKV to AVI (with dual audio track)
By mwasim1 in forum Video ConversionReplies: 1Last Post: 4th Jan 2009, 22:54 -
OGM to AVI Conversion Trouble
By Startropic1 in forum Video ConversionReplies: 5Last Post: 24th Sep 2008, 22:06 -
DVD to avi with alltoavi
By hilario in forum Video ConversionReplies: 8Last Post: 10th Jan 2008, 02:50 -
Converting OGM/MKV to AVI
By DarkManX4lf in forum DVD RippingReplies: 11Last Post: 30th Dec 2007, 15:16
