I'm encoding a 35 minute 720x480 AVI for DVD-R I almost always use 2-pass VBR but was curious about the other settings. I have used CBR in the past for shorter files with 9400 bit rate and it looked great. Any advice on using the CQ setting at 9400 bit rate and the quality slider all the way to 100?
Thanks,
Barney
Ok Ok Ok, I know I'm not as smart as all of you. But look how much smarter I make you look!
CQ=100 is close to CBR. Bitrate 9400 kbps may be to high for your dvd player. However, with CBR 9400 kbps you can fit about 11min 30 sec on one 80min CD.
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 16:59 -
Does powerdirector have 2 pass VBR?
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2009, 00:49 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 21:48 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
2 Pass VBR Problems in TMPGEnc
By Rez. in forum Video ConversionReplies: 0Last Post: 19th Dec 2007, 12:16
