Hi, I am capturing PC game videos using Dazzle 100.
My Nvidia only allows me to CLONE the TV screen to 1024x768 instead of 1280x1024. Is it because of the Dazzle 100? or is it because of my TV?
If I get a better video capture device, will I be able to use Nvidia and clone the TV screen to 1280x1024? or do I have to change my TV?
Thanks.
Most video cards limit the desktop resolution to 1024x768 when using the TV output. Going to a higher resolution wouldn't help -- whatever resolution you are running gets downsized to about 640x480 (an NTSC limitation) before being sent to the TV. A higher resolution desktop would look worse, not better.
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 08:17 -
LCD 720p 1024x768 or 1366x768?
By sina1358 in forum DVB / IPTVReplies: 8Last Post: 12th Dec 2008, 16:44 -
1280x1024 Resolution doesn't fill screen?
By mccoady in forum ComputerReplies: 20Last Post: 17th Oct 2008, 19:56 -
Plasma Resolution...1080p FulHD but 1024x768 res...???
By snadge in forum DVB / IPTVReplies: 40Last Post: 8th Mar 2008, 19:37 -
PLASMA resolution..1024x1080 (or 1024x768) ..surely isnt widescreen?
By snadge in forum DVB / IPTVReplies: 6Last Post: 2nd Sep 2007, 12:24
