Hi All,
I am doing alot of Video_TS conversion of individual title sets to DivX using AutoGk - Is there any way to simply set a default bandwidth to encode at ? and if so, would 900 kbps be good quality ?
I have been setting the bandwidth via the pre-determined sizes - however, I'd like to simply set them all to encode at 900-1000 kbps and auto-resize the A:R accordingly.
Thanks all![]()
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
No, and it's done that way purposely. Of course, you can find the bitrate from the size you want. Have you considered making 1-pass target quality encodes? That way you'll get the predetermined quality that you set, although the filesizes will be completely unpredictable.Is there any way to simply set a default bandwidth to encode at ?
And that's one of the reasons why bitrate encodes aren't allowed. That question has no meaning at all. There are just too many variables to be able to give any kind of a definitive answer to that question. Among other factors are the compressibility of the source, the chosen resolution, and the desired output quality. If you want to set the bitrate, either use AutoGK's big brother Gordian Knot, or learn to encode manually....would 900 kbps be good quality ? -
Read my blog here.
Set Default Player for FLV format?
By schwine in forum Newbie / General discussionsReplies: 9Last Post: 11th Mar 2013, 12:21 -
Subtitle Creator - Unable to set Default Subtitle Colors & Default Prof
By blue2 in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 23:47 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 16:59 -
How can i set subtitle ON by default?
By shay86 in forum Authoring (DVD)Replies: 3Last Post: 3rd Oct 2007, 09:34
