I created a slideshow using Wondershare Photostory. The image is stretched horizontally(people are fat). There was no option to select the aspect ratio. DVDPatch won't recognize the file. Thanks.
All I know is that it has AVI extension. Perhaps the problem is the aspect ratio of the pictures is 3002:2000. I already converted it to MPEG2 using TMPGencPlus and flagged it to 4:3. Seemed to work.
Most digital still cameras take shots with a 4:3 AR, although many also have a 3:2 option as well. If you are working in 16:9 then you either need to crop or reframe in the slideshow software (and not all are smart enough to do this), or crop outside the slideshow program.
Read my blog here.
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
how to get correct aspect ratio when adding subs to avi file using auto GK
By neds81 in forum SubtitleReplies: 5Last Post: 29th Dec 2009, 18:01 -
Correct aspect ratio
By dfisher052 in forum DVB / IPTVReplies: 8Last Post: 25th Oct 2008, 23:34 -
How to correct the aspect ratio (I see it in 4:3 but it should be 16:9)?
By Anonymous74 in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2008, 07:10 -
how to add the correct aspect ratio flag in an avi file?
By graysky in forum DVD RippingReplies: 15Last Post: 23rd Nov 2007, 04:23
