hi guys, i am not a techie so go easy on me. recently bought an easycap video capure device to use with my security camera so i can record on my hard drive. loaded everything up and works fine. only one thing is it uses a serious lot of hard drive space. example is evry 2 secs of recording uses 20 mb and thats it set at 1 fps. is there any way to get more recording time on my hard drive as the guy who sold it to me claims it can record for weeks. also is there any software i can get to make the camera motion sensitive so its only using space when it needs to, instead of having it record all the time.
your advice and help is very much appreciated![]()
There is probably some way to select a video (and audio?) compression codec within the supplied software.
thanks for that. anybody know where i should be looking to find the compression codec?
thanks again for all your replies.
How do you capture(record) your videos device?
By johns0 in forum PollsReplies: 15Last Post: 18th May 2012, 16:30 -
Easycap 2.0 problem with wireless camera...
By tmady in forum Capturing and VCRReplies: 9Last Post: 22nd Apr 2012, 04:30 -
Set up security camera with a usb capture device -- help please
By brenda035 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jun 2010, 10:01 -
Can Easycap Video Grabber Capture card USB 2.0 RCA be used to record Beta
By laslim in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2008, 11:06 -
Need help...Newbie who's just bought "EasyCap" USB Capture Device
By RICHM0802 in forum Capturing and VCRReplies: 1Last Post: 19th Sep 2008, 02:18
