Hi, I am experimenting with Video DJing and I want to be able to capture the output from my laptop and also view the output on a monitor.
I have a MacBook Pro with a DVI output, and today I bought the Canopus ADVC 110 unit. I'm not sure the best way to capture the video output from the MacBook Pro, what cables to use etc. I assume that the DV input (Firewire) would be the best quality input to use on the ADVC 110 unit (compared to the S-Video and Composite inputs) but I cant seem to find a DVI to Firewire type of cable. Does this even exist and would this work?
Ideally I would like to split the DVI output to
a) a monitor or tv so I can watch what I'm doing while I'm DJing and
b) capture the output (as Ive already mentioned!)
I will be using my PC to capture the video
Can anyone make any suggestions as to what my ideal setup would be with the gear that I have?
I don't think you will find a DVI to DV converter, especially not a cable.
DV is a more of a storage format, while DVI is display format, similar to VGA, but digital, not analog, made to hook to a video display. Your choices are probably limited to S-video or composite out from the computer.
You may still be able to use the DVI for output to a monitor at the same time, but some computers may limit you to using VGA out when also using S-video out. Or worse, may only let you use one at a time. One of our Mac users may have better info.
I can move this thread to the Mac forum if you need more specifics on MacBook capabilities.
hi - i just posted another new thread about a similar problem - sorry! it's here https://forum.videohelp.com/topic353930.html
please move to the Mac forum
Canopus ADVC 110 - Capturing in Windowbox
By nharikrishna in forum Capturing and VCRReplies: 6Last Post: 28th Oct 2011, 05:50 -
Capturing issue with Canopus ADVC-110
By nharikrishna in forum Capturing and VCRReplies: 6Last Post: 24th Aug 2011, 12:30 -
Good software for capturing DV with Canopus ADVC 110?
By nikgelfi in forum Capturing and VCRReplies: 12Last Post: 28th Apr 2011, 09:39 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Canopus ADVC 110 video out question
By Darkestred in forum Capturing and VCRReplies: 5Last Post: 3rd Aug 2007, 23:12
