    Jul 2008
    Costa Rica
    What is the best quality of these DVDs?
    Brand Code
    MaxMax GSC003
    Egital OPTODISCR008
    Huskee GSC003
    Princo princo8x02
    Samsung OPTODISCR008
    Skmax mcc 02rg20
    Smartbuy ProdiscF01
    BenQ DAXON016S
    USA
    JMO, but none of the above. If you have no choice, Optodisc has been decent in the past, but I haven't used them in a while. Good quality DVD discs seem to be presently; Taiyo Yuden, Verbatim and some forms of Sony DVD discs. With the others, you may have problems. You can go to http://nomorecoasters.com/ and check out some of your brands.
    But other may have different opinions.
    And welcome to our forums.
  3. Member [_chef_]'s Avatar
    Nov 2002
    Germany
    Only the BenQ discs are useful, all others are a waste, because they are FAKES.
    *** Now that you have read me, do some other things. ***
    BenQ DAXON016S is best there, but if it's made in Malaysia (as opposed to Taiwan), then it's going to be crap too.
    Jul 2008
    Costa Rica
    Thank.
    I will buy BenQ
